Use statistics to help you monitor Open Shortest Path First (OSPF) performance. You can also use statistics in troubleshooting procedures. OSPF range statistics include area ID, range network address, range subnet mask, range flag, and LSDB type.
Switch:1>show ip ospf stats
OSPF Statistics - GlobalRouter
NumBufAlloc: 1138
NumBufFree: 1138
NumBufAllocFail: 0
NumBufFreeFail: 0
NumTxPkt: 1144
NumRxPkt: 2287
NumTxDropPkt: 0
NumRxDropPkt: 0
NumRxBadPkt: 0
NumSpfRun: 19
LastSpfRun: 0 day(s), 00:26:15
LsdbTblSize: 7
NumAllocBdDDP: 5
NumFreeBdDDP: 5
NumBadLsReq: 0
NumSeqMismatch: 0
NumOspfRoutes: 7
NumOspfAreas: 0
NumOspfAdjacencies: 3
NumOspfNbrs: 3
NumEnabledOspfAreas:0
Use the data in the following table to use the show ip ospf stats command.
Variable |
Value |
vrf WORD<1-16> |
Specifies a VRF instance by VRF name. |
vrfids WORD<0-16> |
Specifies a VRF or range of VRFs by ID. |
